Veröffentlicht Sun, 13 Jan 2019 19:37:53 GMT von Cristian Gonzalez Ingeniero de Sistemas
I am trying to update docuware from version 6.12 to version 7, the update I am doing in a test machine that is a copy of the production machine, in the step of authenticating with the existing database the system throws the following error: Getting DB Connnections failed. I already checked the dwmachine file and everything is fine. Thanks for the help
https://www.docuware.com/sites/default/files/forums-images/error.jpg
Veröffentlicht Mon, 14 Jan 2019 12:15:43 GMT von Craig Heintz SE
v7.0 requires the DB connection to the server and instance where 6.12 was forgiving.  Even if you are using the default instance.  This is true throughout any config screen that requires DB connection info.  So, below are two examples of how it may need to be input.  Note the slash is required in the second example.  You can prove that you have the right string of characters by connecting wit SQL Mgmt Tool with the string first.
dbservername\instance
or
dbservername\
Veröffentlicht Mon, 14 Jan 2019 14:29:11 GMT von Cristian Gonzalez Ingeniero de Sistemas
The error appears on the test server, which is a copy of the production server, and I'm actually entering the instance and the name of the server. what we are doing is first update from v6 to 7 first on the test server before going to production
Veröffentlicht Mon, 14 Jan 2019 14:39:14 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Cristian,
The Port seems odd "predetermined". Please change that to either -1 for default,1433 for the standard MSSQL or whatever port it is running on.
Veröffentlicht Mon, 14 Jan 2019 14:44:59 GMT von Cristian Gonzalez Ingeniero de Sistemas
Thanks, the port also took it into account and remove the value -1 for the 1433, but this change does not work either
Veröffentlicht Mon, 14 Jan 2019 14:50:22 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
I think that support needs to take a deeper look. Can you open a support request?
Veröffentlicht Mon, 14 Jan 2019 14:57:18 GMT von Cristian Gonzalez Ingeniero de Sistemas
Yes sir, thank you very much for the help
Veröffentlicht Thu, 22 Oct 2020 09:36:16 GMT von Damian Scheiding
Can you tell me how you solved this problem?
Damian
