I created an ODBC data source for my Sybase and SQL database. The ODBC connection test came out successfully for both.
When I try to configure Autoindex to use those ODBC data sources, however, I am getting an [object object] error message.
Is this something you have encountered before? Is Autoindex able to use 32-bit and 64-bit ODBC drivers? I'm thinking it could be a driver issue, but then the ODBC test was successful.
Thanks!
