Veröffentlicht Tue, 12 Nov 2024 22:02:39 GMT von James Strnad
I have been reviewing the PowerAutomate API for DocuWare: https://learn.microsoft.com/en-us/connectors/docuware/#search-for-documents
I am having issues with the Search for Documents API. One of the parameters is "Search Query". I don't know what should be put here to make the call work. There is no guidance on the correct format for this parameter. Is this a index field name? A FileCabinet?
Can anyone advise what a proper parameter would look like?
Veröffentlicht Wed, 13 Nov 2024 09:13:37 GMT von Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi James Strnad,
I have not used the PowerAutomate connector yet, but I would guess that it is just based on the DW REST API and uses mostly the same methods and the same format.
Maybe you can find what you are looking for here: https://developer.docuware.com/
Veröffentlicht Wed, 13 Nov 2024 15:30:26 GMT von James Strnad
Hi Simon,
Thanks for your response. I am not very technical so it is hard for me to understand JSON and other in this document.
If I can get some feedback about what the expected input would be in this field would be really helpful.
I found this (attached Query.png) at line 1853: but I am not sure if something like this is what needs to be put in this parameter field.
If anyone could confirm I would be eternally grateful.
best regards
James
Veröffentlicht Fri, 15 Nov 2024 11:07:05 GMT von Tobias Getz DocuWare GmbH Team Leader Product Management
Hi James,
documentation for the Power Automate Connector is available in the Knowledge Center.
This is a basic example for the search in one field:
{"DBNAME":["Value"]}
DBNAME - The index field name. This should be capitalized as shown in the example above.
Value - The value for the specified index field. Note that the ‘Value’ also supports operators such as *, OR, and NOT.
