Veröffentlicht Fri, 24 Sep 2021 14:43:19 GMT von Lee Wiltshire Technical Director
I have a customer using intelligent indexing on invoices involving line items. On some of his line items, in the Product Description, he can potentially have some commas in the description  for example 3,000metres. When we  use the Exporter module and export the data to CSV, the Product Description is split to a new cell everytime it sees the comma. Is there any way to overcome this?
Veröffentlicht Fri, 01 Oct 2021 14:43:19 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Lee Wiltshire! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-160944-Y3G3Y for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Veröffentlicht Mon, 04 Oct 2021 13:09:02 GMT von Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Lee,
either use text replacement operations in WF designer prior to exporting or use a proper csv separator, like ;
Veröffentlicht Tue, 09 Nov 2021 07:15:25 GMT von Morten Ravn
In the export module in webconfig.. can't you just select this.. look in attachment..
