Veröffentlicht Tue, 13 Nov 2018 14:22:07 GMT von Hameed Ogbara - left 05.2022 Technical Support
Hello House, An hyperlink was sent to a user in docuware. Upon opening the document, it was blank. When the Docuware Administrator tried opening the document using the hyperlink, it opened a blank page. Regards.
Veröffentlicht Thu, 15 Nov 2018 16:35:08 GMT von Casey Miller Director of Technical Services
do you have any filters turned on for the dialogs? I have seen this when there are filters turned on and the users don't have access to the document in the dialog.
Veröffentlicht Fri, 16 Nov 2018 12:32:56 GMT von Hameed Ogbara - left 05.2022 Technical Support
Hello Casey,
Which filters are you refering to. Is this filter done by the user or the administrator.
Veröffentlicht Fri, 16 Nov 2018 17:32:14 GMT von Casey Miller Director of Technical Services
would be done in administration. I am referring to setting up filtered dialogs for users to restrict access to certain documents in the file cabinet.
