Veröffentlicht Thu, 13 Feb 2020 12:51:46 GMT von Craig Heintz SE
Has anyone else experienced that when 2 filter profiles are assigned to a Role like this:
1.  DocumentType=Invoice (search, view, export)
2.  Document Type=Invoice and Security=Locked (search, View)
When a user does a search and the result list includes documents that have a mix of both match scenarios above, when a user opens either document match, the viewer tools will change based on which match exists.  For instance the download tool will gray out when match#2 matches.
However, in the result list, if I right click the same document, the Download link is still there.  If I click it it begins the action but then opens a new window and errors out with a permissions reason.
So here is my question...Is there any way to make the viewer tools and the right click menu work the same?
Veröffentlicht Thu, 13 Feb 2020 12:53:20 GMT von Craig Heintz SE
Here are screen shots
