Veröffentlicht Thu, 28 Apr 2022 21:48:09 GMT von Luis Flores
I am trying to figure out how to create a list that shows documents that contain a specific string in a keyword field. The list would only show documents if this keyword field contains one row with this string.
For example, if the table contains only ['A'] then the document will show, but if the table contains two rows, ['A','B'] then the rule is false. I've tried using a LIKE statement with the Is (where clause) option, but it doesn't seem to work if there are multiple rows in the table. Setting the WHERE string to '%A%' also doesn't return what I'm looking for.
I think if I could figure out the syntax for a 'doesn't contain' statement then that would solve my issue as well. Although NOT LIKE seems to not work either.
Thanks!
Veröffentlicht Fri, 06 May 2022 00:00:12 GMT von Matthias Wieland Senior Director Support EMEA
Dear Luis Flores! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-175888-K5K9P for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
