Veröffentlicht Thu, 04 Mar 2021 19:43:03 GMT von Steve Shriver Application Specialist
Back in the days when AutoIndex was configured using the Admin tool it was possible to filter records using relative dates, 'Within the last x days', 'Before the last x months' etc.
Now the choices all seem to be based on a specific date, Is before, is after, and so forth.
Is there anyway to configure a relative date? I'm looking specifically for 'within the current year' so that I do not have to remember to change the configuration every Jan 1st.
Veröffentlicht Fri, 05 Mar 2021 13:59:15 GMT von Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Steve,
as far as I know, all possibilities from the DocuWare Administration are also available in the new configuration. They might have a different naming, but should work the same. I do not know exactly how to configure "Withing the current year" but if it was possible before, it should be possible now also.
I hope this helps.
Veröffentlicht Fri, 05 Mar 2021 16:59:44 GMT von Steve Shriver Application Specialist
Tobias,
Looking closer I believe you are correct. The date filter options are expanded if you use a file event or scheduled AutoIndex. They are restricted to specific dates when use a file cabinet event configuration.
Many thanks,
Veröffentlicht Mon, 08 Mar 2021 08:00:06 GMT von Tobias Getz DocuWare GmbH Team Leader Product Management
Steve,
as soon as you can use Version 7.4 the filter options for dates are the same in event based and scheduled Autoindex.
