Veröffentlicht Fri, 24 May 2019 06:25:35 GMT von Mayra Rossi
It's possible to split file into multiple documents on document import (with document processing)?
For example, if I need to extract page 13 from my document (80 pages) it's possible to take only page 13? It's possible to take page 13-16?
Veröffentlicht Fri, 24 May 2019 10:43:27 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
DocuWare Import can split every x pages but not on an abitrary and constantly changing page count. To split on a specific page you must be able to identify a unique attribute on the page to split on. So if page 13 and page 17 have an attribute that can only be found on those pages then yes you could split on that.
So for example say the unique attribute was the word Split. Then you would tell DocuWare to split when it found that word at a specific location.
Then you would get 3 documents:
Pages 1-12, 13-16, and 17-80.
You will need the Barcode & Forms module to accomplish this.
Senior Director Client Services Americas
Veröffentlicht Fri, 14 Aug 2020 19:12:14 GMT von Jon Weston File IT Solutions Sr Application Developer and RIM specialist
Is document splitting not available for 'Folder' configurations? I'm only seeing it when I select Scanner or Printer as the source.
