Veröffentlicht Mon, 03 Apr 2023 10:49:33 GMT von Winston Ong Senior Digital Services Consultant
Hi there,<br> <br> From DocuWare interface in Document Tray, we could create a data record in cabinet, e.g. create an entry of Index Field values without any document.<br> <br> Is there any API method in DocuWare that performs the same operation?<br> <br> Thank you.
Veröffentlicht Mon, 03 Apr 2023 12:45:08 GMT von Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Winston,&#160;<br> <br> you can use the regular UploadFile Methods without adding files. That will create a data record.<br> <br> Hope this helps.<br> <br> Greetings from Germany,<br> Simon H. Hellmann<br> DocuWare System Consultant
