Veröffentlicht Fri, 26 Mar 2021 10:12:57 GMT von Wolfgang Rabl
with the Docuware Desctop Apps it is possible to define a folder to be monitored.
If a file is put there with a corresponding .dwcontrol file it is then automatically imported and processed into docuware.
However thats a use case for a single user monitoring his files and he has to locally run the desktop apps on his computer.
Is there a possibility to create such folder monitoring generally?
So that there is e.g. a network drive monitored and everything anyone puts there will be imported to docuware without some user running the desktop apps on his local pc (maybe via a job on the docuware server)?
thanks
Wolfgang
Veröffentlicht Fri, 26 Mar 2021 11:04:31 GMT von Simon H. Hellmann Toshiba TGIS GmbH | IT-Consultant - Document Management Solutions
Hi Wolfgang,
you can just install the Desktop Apps on the server hosting the share and have the fileserver do the monitoring.
Monitoring a SMB Share is also possible, e.g. have the share on Server1, Desktop Apps on Server2 monitor the UNC path of the share on Server1.
Greetings,
