Veröffentlicht Fri, 14 Feb 2025 01:48:02 GMT von Paolina Lee Document Control Manager
Hi all,
When setting up a form, I’m struggling to choose between Web Form and Merge Form since both have their pros and cons. I’m wondering if I’m missing a configuration option or if these limitations are inherent to the product. Attached actual exported files for your reference.
1. Web Form:
  • Can the Table Field in the designer adjust its width dynamically based on the value length, or at least be manually adjusted?Sometimes, the value is less than 8mm, but the exported PDF appears fixed at 39mm based on the Form Width Pixels.
  • Can user instructions be hidden after submission?
    I’d like them to be visible for applicants but hidden in the exported PDF.
  • Can unselected values in a Ratio Field be hidden?
    I need applicants to see all options but only display selected values in the exported PDF.
2. Merge Form:
To address the issues above, I tried using a Merge Form, and it worked well for my needs. However, I ran into one major obstacle:
  • After submission, Table Field values don’t appear in the exported Merge Form file (no matter PDF, Word, or Excel).
    Is Table Field designed merely to be collecting the data into entries? or how Table Field should be used in Merge Form?
Has anyone encountered these issues before or found workarounds? Any insights would be greatly appreciated!
Thanks!
Veröffentlicht Sat, 22 Feb 2025 00:00:27 GMT von Matthias Wieland Senior Director Support EMEA
Dear Paolina Lee! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-255761-C0X9N for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Veröffentlicht Wed, 09 Apr 2025 19:23:24 GMT von Joann Pendleton Data Analyst
Any solutions to this?  I'm seeing that I don't even have an option to add a table to a merge form.
Veröffentlicht Wed, 09 Apr 2025 21:14:19 GMT von Juan Cassis TGI Office Automation Systems Engineer
I am dealing with the same issue! If data from a Table field in a form is not able to merge the data to a merge form...then remove the table option from the Form Designer Fields list when an user is using a merge form....
Veröffentlicht Wed, 07 May 2025 11:59:50 GMT von Gerardo Lisanti Team Leader Product Management
Hi Joann and Juan,
unfortunately table fields are currently not supported in merge forms. If you like you can vote for this extension in our customer feedback forum:
Provide a way to store table values from eforms and/or workflow on to merge forms – DocuWare Customer Feedback Forum
Best Regards
Team Leader Product Management  |  DocuWare GmbH
Veröffentlicht Sat, 17 May 2025 14:42:34 GMT von Javier Sanchez IT Support
Hello
At the moment it is not possible to apply directly the values of a table in the area mapping of the merge form, but you can do it through the workflow.
You should enable the form to be editable in the merge form configuration, create the fill areas but without assignment and in the workflow assign the values of the table to the fill areas of the form.
