Posted Sat, 22 Sep 2018 19:39:38 GMT by Joe Kaufman Bell Laboratories Inc Application Development Manager
Hey all,
A third-party CMMS system is offering to send us a MS SQl Server BAK file containing the full system database, daily, so we can mount it on our SQL Server and have all data locally for our own reporting, etc.
Problem is, they are backing up from SQL Server 2014 and our SQL Server is 2012. This server is the database upon which our on=premise DocuWare system resides.
We are on DW 6.11 with all hotfixes installed. Can we simply upgrade SQL Server from 2012 to 2014 without issue? I am assuming so, just wanted to make sure.
For that matter, should we just go all the way to SQL Server 2016? Will that work OK for DocuWare 6.11? we do not have the resources to try all this on a test server and test every single file cabinet and task manager setup. If all goes haywire, we would simply restore the entire DocuWare server image (which includes SQL Server) from backup (the server is virtualized). Apolgies if there is a upported database listing somewhere that I missed (I did search the forum but couldn't find anything quite specific to our scenario).
Let me know any gotchas with upgrading SQL Server behind DocuWare, and any downside to just going all the way to SQL Server 2016. We might as well, assuming it doesn't have any obviously pitfalls.
Posted Tue, 25 Sep 2018 10:46:56 GMT by Joe Kaufman Bell Laboratories Inc Application Development Manager
Hey all,
Does anyone have any thoughts or "gotchas" about this? Any documentation I may have missed on upgrading the database behind DocuWare?
Posted Tue, 25 Sep 2018 11:13:19 GMT by Phil Robson DocuWare Corporation Senior Director Client Services, Americas
Joe,
The only gotcha when upgrading the database is to ensure that it is a supported DB version for your version of DocuWare.
6.11 supports MSSQL versions to 2016. So you can go to that.
Posted Tue, 25 Sep 2018 12:00:56 GMT by Joe Kaufman Bell Laboratories Inc Application Development Manager
Thanks, Phil!
Where can I find the various compatibility lists between versions of DocuWare and SQL Server, IIS, Windows Server, etc. I assume all of those dependencies are lain out somewhere.
I will look into getting us updated to 2016!
Posted Thu, 04 Oct 2018 13:04:24 GMT by Tobias Getz DocuWare GmbH Director Product
Hi Joe,
the system requirements are inside the Knowledge Center. For 6.11 you can find them here: http://help.docuware.com/en/#b57853t63146n87396
To see them for other versions, you have to choose that version from "Options" in the toolbar.
If system requirements are changed, you will find this in the "What´s new" section for every release, e.g. here: http://help.docuware.com/en/#b57865t57866n82340
Posted Thu, 04 Oct 2018 13:20:18 GMT by Joe Kaufman Bell Laboratories Inc Application Development Manager
Tobias,
Thank you -- great info!
