- I have a customer who wants to store about 12,000 documents and he wants to use DW Import templates to do it.  There are two types of documents; checks and letters.  The checks are related to the letters by a matching account number and dollar amount (required for Stapler job).
- He wants to extract the account number and the dollar amount contained in both.
- I have two questions...
-   FIRST, the 17-digit account number is represented on both document types using hyphens for ease of reading, but the hyphens are not used in the DW file cabinet.  The ACCOUNT NUMBER field in DW is a VARCHAR 20 field with no mask assigned (I guess they just manually type the 17 digits when storing a new document to the file cabinet).  What is the best way to OCR the account number and store it w/o the hyphens?  I cannot find the DW Import template equivalent the way you could configure the DW Windows Desktop Client REC2 module to ignore specified characters.
- I thought perhaps the answer was to create a mask for the field, but nobody seems to understand REGTXT enough to suggest the correct filter syntax.  Not sure this would work, but until I have the correct REGTXT I can't teat it.
- SECOND, the letters contain a dollar amount as part of the text.  The dollar amounts vary from $.nn up through $nnn.nn. The dollar amount is immediately followed by a comma to set the amount off in the sentence to which it belongs.  Again -- in the old DW Windows Desktop REC2 module we could set an OCR zone and have it garb everything between the "$" and the comma -- but no similar function in Web Client DW Import.
- I can use the character count filters because the character counts vary based on the dollar amount.
- I see that there is a substitution function in DW Import template, but I can't figure out how to make it work.
- Any suggestions?
