Posted Fri, 01 Feb 2019 11:26:15 GMT by Phi Quan - left 09.2021 IT Manager
Hi, I would like to implement a multiple column drop down to let the user choose an entry for a fiel in a from of a task.
But it does not work.
I have added a txt file utf8 txt file (GewerkKonto.txt)with following content:
1000;Abcd
1001;Testtext
1003;Blablablah and so on
1004;end of test
so my question is, how do I set up this or can I only offer drop downs with just 1 column in a descision of a task?
As you can see in my screenshot I won't be offered the GewerkKonto.txt
https://www.docuware.com/sites/default/files/forums-images/2019-02-01_13_24_15-aufgabe.jpg
Posted Fri, 01 Feb 2019 11:42:58 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Select lists are designed to only display and allow selection of a single column. Showing multiple columns and allowing selection of a specific column is not supported. However, We do support multi-column select lists where the entry of a value in one field, can be used to filter the values in another field.
http://help.docuware.com/en/#b64084t62404n87514
Senior Director Support Americas.
Posted Fri, 01 Feb 2019 15:15:56 GMT by BONNEAU Stephane CEO
Dear Phil,
What a pity to not have an uri for calling that described in title....
Maybe further minor updates of DW7.1 ?
And why not adding value in those selection list ? that may permit the repository of our customer to be uptodate...waaowww
(Better than a poor csv file , no ?)
regards,
Stephane
Get Help
Chatbot Button
