Posted Thu, 08 Feb 2018 17:40:11 GMT by Bary Leach
Is there a guide on the syntax for searching in the Web Client.  I'm using 6.9 and I have a Invoice Amount field and I want to search for invoices less than 0 and ones that are 0 and ones that are greater than 0.  '< "0"' seems to work for invoices less than 0, but '= "0"' and '> "0"' don't seem to work.
Posted Thu, 08 Feb 2018 18:00:04 GMT by Joe Kaufman Bell Laboratories Inc No longer there
Bary,
First off, thanks for turning me on to these operators -- had no idea you could even do that!
I assume you are referring to searching on a string (text) field, because dates and numeric values already use a range.
I am betting you are simply forgetting to uppercase your AND. Keywords like AND, OR, and NOT always need to be capitalized. I just did a test on a search for an index using the expression:
<= "Y" AND >= "S"
and I got all the documents where that field started with S, T, U, V, W, X, and X. (no "Y" values because any string starting with "Y" that wasn't exactly "Y" wouldn't make it in). So it looks like it works, and you can use "<=" and ">=" in addition to =, <, and >.
Looks like you can even use wildcards in the expressions to create even more powerful searches!
Hope this helps!
Posted Thu, 08 Feb 2018 19:07:29 GMT by Bary Leach
Thanks, that does help!
Posted Thu, 08 Feb 2018 19:28:25 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
= "*A*"  - anything containg A
="A*" - anything starting with A
=*A" - anything ending with A
= "A*" AND "*B" - starts with A and ends with B
Posted Thu, 08 Feb 2018 20:09:09 GMT by Joe Kaufman Bell Laboratories Inc No longer there
Phil,
The "=" operator is not working for me the way you are describing it. It appears to be an exact match sort of thing.
I tried a search expression on a text field: "*Z*" (no equals sign) and got 4400 documents returned.
I put an equals sign in front and got zero documents back. It did not matter whether or not I had a space between the equals sign and the expression.
Changed the equals sign to a ">" (greater than) and got the whole cabinet back (well, the 30,000 document search maximum I have set up).
Like I said, the "=" seems to enforce an exact match, and does not honor wildcards. I am not sure if it treats the asterisk as a literal asterisk in that case or what.
I am running 6.11 on-premise.
Posted Thu, 08 Feb 2018 20:12:44 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Sorry Joe,
The equal sign is not required. I should have clarified that.
The = is assumed. So the exact entry would be "*A" OR "B*" etc.
Phil
Posted Thu, 08 Feb 2018 20:17:55 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Clarification. The search criteria is determined depending on the syntax. So entering a string such as Phil will generate an = search - WHERE field = 'Phil'
Entering Phil* will generate a LIKE search: WHERE field LIKE 'Phil%'
and so on.
Phil
Get Help
Chatbot Button
