Posted Fri, 27 Apr 2018 16:45:11 GMT by Keith Telford App. Support
we are using the clip feature in docuware ..we will sometimes clip an email to a document that has been filed ..can you undo a clip once it is clipped
Posted Fri, 27 Apr 2018 16:49:17 GMT by Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Keith,
No. You would need to copy the document to  a tray, unclip it there and restore it as a new document.
Posted Mon, 30 Apr 2018 11:55:36 GMT by Casey Miller Director of Technical Services
Keith, if you turn on versioning, you can check it out. Then unclip the document and check it back in. The caviot is that the deleted document would have to be the second document for this to work or you can't check back in.
Posted Mon, 04 Nov 2019 10:28:23 GMT by Marcin Kratiuk
Another side effect is that once you check out / check in document - you are not able any longer to edit this document from file cabinet using edit button (pencil icon). For example you have a word document clipped and once you did check-out / check-in in order to remove some other clipped files then you will not be able to edit this word clipped document anymore - only option will be to do again check-out and check-in.
