Posted Wed, 12 Sep 2018 18:27:17 GMT by Craig Heintz SE
A support case has been opened for this issue
Posted Fri, 14 Sep 2018 18:37:07 GMT by Josef Zayats
Greg,
where is your original post on this? That was a great find.
It seems that the problem is even wider than you described: even if you pick a value for field1 and select list for field 2 is limited to corresponding values for the selective select list - the way it should be, but if you type anything in the field2 from select list for column2 - it will still allow you you to store.
In short, in DW7, external Selective Select list only works for dropdown values, but does not work to restrict store values.
Hope Docuware will issue a hotfix soon.
Posted Sat, 30 Mar 2019 14:24:09 GMT by Craig Heintz SE
v7.1 fixes this issue.  I have tested it in the trial version and it appears to work are prescribed.
FYI
Posted Mon, 01 Apr 2019 21:23:11 GMT by Casey Miller Director of Technical Services
hopefully there is a hot fix for this as I don't normally update my customers until I know it is stable release
