Posted Thu, 23 Aug 2018 07:27:49 GMT by Jacek Musiał
I have problem with docuware date.
Yesterday i had date format like that :2018-08-22
Now i have this format  06.07.2018.
I can't import documents from docuware online to my workflow system because date format was changed in all field with date
How can i change date format to old format ?
Regards and thank you for your help.
Posted Mon, 10 Sep 2018 20:02:13 GMT by Craig Williams President/ CEO
I think I need to see more specific information.
Date format Where? In Docuware? On the Document being added to the workflow...
Help me understand more.
Posted Fri, 05 Oct 2018 05:02:00 GMT by Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Jacek,
generally the dates in DocuWare are stored in an universal format and the client displays the date then in the local time zone and format.
There might be some exceptions, but this is the general approach for all date fields. If you have a date in a text field, then this is not changed at anytime. As it is a text field, it will remain the same.
Maybe you should describe your issue a little bit more, so we can help.
