Publicado Fri, 01 Apr 2016 17:39:40 GMT por Tim Walsh Solutions Intagrator
Just upgraded Fortis 2.5 to 6.8. Now the client can't print to Fortis to the Database or an inbasket. They get a dialog box that asks for an output file name and they can only send to a file folder. I know we added a Fortis Color printer abd there is now no ntprint application that I could find.
Is this a normal behavior in 6.8 or is there something we can do to fix this?
Publicado Fri, 01 Apr 2016 17:47:53 GMT por Chad Folts Professional Services Engineer
Tim - Is the Login button greyed out?  If so make sure the Path variables in the following registry locations is pointing to the Fortis directory on the server:
HKEY_CURRENT_USER\SOFTWARE\Westbrook Technologies\Fortis\InstallInfo\Path
HKEY_LOCAL_MACHINE\SOFTWARE\Westbrook Technologies, Inc.\Fortis\InstallInfo\Path
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Westbrook Technologies, Inc.\Fortis\InstallInfo\Path
Publicado Mon, 04 Apr 2016 17:04:37 GMT por Tim Walsh Solutions Intagrator
This one is not there at all. The other two were, except that on had the local folder c:\Program files as the path.
It seems to be working no. I did run NTPRINT manually on the server though. Don't know if that was why it started working.
One thing though, it does not retain the login info. The user has to login each time. Is that normal or is there a way to save that info?
Publicado Mon, 04 Apr 2016 17:05:16 GMT por Tim Walsh Solutions Intagrator
This is the one not there.
Publicado Mon, 04 Apr 2016 17:16:48 GMT por Chad Folts Professional Services Engineer
Tim - Have the user uncheck the "Auto Logout" box before submitting it to the printer.  That will leave it logged in for future prints.
Publicado Mon, 04 Apr 2016 17:35:42 GMT por Tim Walsh Solutions Intagrator
No Auot Logout box.
Using the Color Print for Fortis Printer. That is the only printer available except PDF printer which we don't use.
Is there something missing here?
Publicado Mon, 04 Apr 2016 18:11:28 GMT por Chad Folts Professional Services Engineer
It sounds like the Fortis Document printer did not get installed properly.  Try running the setup.exe from the \Fortis\NTPrint folder.  You will then have to update the registry entries I mentioned earlier in this thread to point to the Fortis directory.
Publicado Tue, 05 Apr 2016 10:54:07 GMT por Tim Walsh Solutions Intagrator
OK getting closer. I ran the install and removed the printer. Ran again and installed the printer again. Now all three registry entries are there and the Fortis Document printer is there. The Inbasket option is still greyed out along with the Auto Logout button.
The regisrty entries should point to the unc path or the local path?
Publicado Tue, 05 Apr 2016 14:17:24 GMT por Tim Walsh Solutions Intagrator
I finally got irt working.
