Publicado Thu, 03 Mar 2016 18:01:55 GMT por Tim Walsh Solutions Intagrator
Upgrade from Fortis SE 2.5 to 2.6. After running the upgrade it asked for a reboot. After the reboot it started the WTI install shield. Now I have a command prompt window witht he title c:\windows\syswow64\icads.exe. Nothing has happened for 20 minutes.
Is this normal or should I close that window and pray?
Publicado Thu, 03 Mar 2016 18:35:07 GMT por Tyler Behuniak Professional Services Assistant
Tim,
This does not seem like normal behavior, if it is still happening can you open up a ticket through our support portal? We will be able to pick up the issue from there.
