Publicado Mon, 18 Oct 2021 11:58:33 GMT por Jonathan Bertossa
I'm trying to sync active directory user using a active directory group that contain other AD groups (nested group).
Unfortunately users in nested groups are not added as docuware users.
It is possibile sync active directory nested group?
Publicado Tue, 19 Oct 2021 14:03:47 GMT por Craig Heintz SE
Groups within groups works.  Are you using the Admin Tool or The User Sync Desktop App to set his up.
Keep in mind that if the users are in a child domain, it will not work.  Only users listed in the connected domain level will synchronize since the pointer to their user attributes are located there.  In this scenario you would have to set up a sync at each domain level.
Publicado Fri, 22 Oct 2021 07:52:37 GMT por Jonathan Bertossa
@Craig Heintz
Thank you! The problem was the position of the OU on the sync configuration.
Regards Jonathan
