<p>I need to change the index field of multiple docs with the same Project code.</p>
<p>The reason is that i need to add an A for amendment required or a C for project s that are goiong to be cancelled.<br> <br> I start the work flow with a task where they can select cancel or amend and that chages the WF-Status to a WF06 (Amend Quote) or a WF16 (Cancel Quote )</p>
<p>i can only get it to do either of 2 things.</p>
<p>1) The current doc changes and the next document changes but no other docs will change no error/fault</p>
<p>2) The current Doc changes and the next document changes but no other docs&nbsp; and will show a fault of there are 1 or 0 docs.</p>
<p></p>
