Publicado Wed, 02 Nov 2022 14:51:44 GMT por Dean Birks ABC Digital Solutions LTD Professional services
<p>I need to change the index field of multiple docs with the same Project code.</p> <p>The reason is that i need to add an A for amendment required or a C for project s that are goiong to be cancelled.&lt;br&gt; &lt;br&gt; I start the work flow with a task where they can select cancel or amend and that chages the WF-Status to a WF06 (Amend Quote) or a WF16 (Cancel Quote )</p> <p>i can only get it to do either of 2 things.</p> <p>1) The current doc changes and the next document changes but no other docs will change no error/fault</p> <p>2) The current Doc changes and the next document changes but no other docs&amp;nbsp; and will show a fault of there are 1 or 0 docs.</p> <p></p>
Publicado Wed, 02 Nov 2022 14:59:47 GMT por Dean Birks ABC Digital Solutions LTD Professional services
Ignore this. I just need to use the Autoindex.
Sorry.
