Publicado Wed, 04 Jul 2018 10:50:56 GMT por Martin Kreft
Hello.
I have to generate a huge amount of data records.
With the "Crate data record" button in my inbox this will take to much time.
I tried to program a small application (C#) for automated creation, but i have problems finding the correct methods for accessing the data record dialog in the API.
Can someone help me with a code snippet or somethig else?
Publicado Thu, 05 Jul 2018 11:42:16 GMT por Joe Kaufman Bell Laboratories Inc Application Development Manager
Martin,
To create a data-only document, I have not used C#/.NET, but have it working from Visual Foxpro (or any language that can manipulate an HTTP request object).
The resource in play is this one:
/DocuWare/Platform/FileCabinets/{cabinbet guid}/Documents/
and then once I have an HTTP request object instance established (in this case, "_DWPlatformService"), the code to POST the request looks like this:
_DWPlatformService.Open("POST", "<URL involving the resource listed above>")
* Need to use a Content-Type of "application/xml" otherwise the POST will simply create a document with the index data XML inside it.
_DWPlatformService.SetRequestHeader("Content-Type", "application/xml")
_DWPlatformService.Send(<POST data>)
The POST data looks something like this, for a cabinet including indexes COMPANY and SENDER as an example:
<Document xmlns:s="http://dev.docuware.com/schema/public/services" xmlns="http://dev.docuware.com/schema/public/services/platform">
    <Fields>
        <Field FieldName="COMPANY"><String>Data Only Company</String></Field>
        <Field FieldName="SENDER"><String>Data Only Sender</String></Field>
    </Fields>
</Document>
This will create a data-only document in the desired file cabinet.
Publicado Thu, 05 Jul 2018 11:55:15 GMT por Martin Kreft
Thank you.
I developed a solution with a empty PDF but this should do better.
Publicado Thu, 05 Jul 2018 12:16:57 GMT por Joe Kaufman Bell Laboratories Inc Application Development Manager
Martin,
We were doing that as well before we figured this out -- happy to help!
Publicado Fri, 06 Jul 2018 04:46:00 GMT por Martin Zebedies
Answert on an other way
Publicado Fri, 06 Jul 2018 06:56:32 GMT por Martin Kreft
Hello.
A colleague was able to help me today.
He knew this function from GAPI and could show me the API variant.
It works in C# quite simply via ShemaExtentions:
SchemaExtensions.PostToUploadDocumentForDocumentAsync(<DwConnection>, <ArchiveGuid>,<Document() with the IndexData>);
Publicado Fri, 06 Jul 2018 10:50:39 GMT por Joe Kaufman Bell Laboratories Inc Application Development Manager
Martin,
Glad you figured it out in the .NET environment, and thanks for posting (will be good for future reference when searching for soulutions!).
