Publicado Fri, 22 Jun 2018 16:17:24 GMT por Raechel Prince Executive Director
I am having some confusion regarding installing the hotfix for DocuWare 6.11.  The instructions mention that the folders do not need to be moved if they are not part of an installed module.  It also mentions that folders will need to be overwritten when copying.  None of the folders in my "C:\Program Files (x86)\DocuWare" match the folder names in the hotfix.  Is this normal and should I copy the folders anyway since nothing will be overwritten?
https://www.docuware.com/sites/default/files/forums-images/screenshot.png
Publicado Mon, 25 Jun 2018 04:03:34 GMT por
Hi Raechel,
are u using an on premise or cloud system?
Publicado Mon, 25 Jun 2018 10:27:52 GMT por Raechel Prince Executive Director
We are using on premise.
Publicado Tue, 26 Jun 2018 03:33:29 GMT por
Then the install-path was changed during installation.
maybe you find the folders at "d:" or in the root of "c:".
