Publicado Thu, 07 Jan 2021 18:20:14 GMT por Daryl Foxhoven
So I have a situation where in my workflow I need to count the # of entries that meet a certain index criteria.  In my case, I'm counting the # of Packing Slips that have the same invoice # that meets the index value of the invoice (that triggers the workflow).  I'm trying to use an Arithmetic Expression with the following and it's not working.
COUNT (DW_INVOICE__= GV_Packing_List_Invoice_No) AND (DW_DOCUMENT_TYPE = 'Packing List')
DW_INVOICE = Invoice # of the document that triggered the workflow
GV_Packing_List_Invoice_No = GV that is capturing the Invoice # of the Packing Slip in an earlier step
Thanks!!
Publicado Thu, 14 Jan 2021 18:20:15 GMT por Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Daryl Foxhoven! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-141997-G9W4N for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Publicado Fri, 15 Jan 2021 11:50:59 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Daryl,
I think your arithmetic expression is a fancy way to say "2".
If you want to count the number of documents meeting your criteria inside the file cabinet, you need to look it up in the database in your "assign data" step, however, this only works if your expected result is 100 or less.
f you expect more than 100 entries, you may need to use a webservice which searches for the number of documents and returns the number of results or rethink if this is the only way to reach your goal.
