Publicado Mon, 05 Mar 2018 17:48:51 GMT por Daryl Foxhoven
Is it possible to Disable Edit Multiple Index Entries either via a Profile OR some sort of global setting?  Customer doesn't want users to be able to do a mass index entry update for all documents.....but they do need the ability to do it on a document by document basis....is there a way to accomplish this via a global setting or profile?
Publicado Mon, 05 Mar 2018 19:17:47 GMT por Tim Ohm
That is a function that can be enabled/disabled on the result list dialog, at least in 6.11 and prior.  Not sure if that changed in 6.12.  So you'd need to make a separate Role for the users you want to be able to change multiple documents at the same time, with a specific Search/Result dialog combo assigned that has the function enabled.
