Publicado Sun, 10 Feb 2019 11:06:39 GMT por David Miguel Trujillo
Hello everyone,
I would like to know how could I obtain the number of pages of a document in DW Cloud, I tried trough a Workflow but I cant find any global variable that contains the number of pages,
Thanks in advance, David.
Publicado Sun, 10 Feb 2019 13:22:05 GMT por Josef Zayats
David,
here is how this can be achieved using AutoIndex Job.
Make sure you know name of your File Cabinet database table (here we use fctable) and your Filecabinet has a numeric field to accept docuement total pages(doctotalpages)
Create an AIX job - I recommend scheduled job with selection criteria 'doctotalpages is empty'
On Match Data Tab - Configure Data Source, select connection GUID_autoindex, SQL Command, type in the following statement
select docid,sum(totalpages) as doctotalpages from fctable_sec group by docid
Match FIlefd : Doc ID is equal docid
Assign Data: doctotalpages - Field - doctotalpages
Run the job - it should fill you doctotalpages column with total number of pages for the document.
Publicado Wed, 13 Feb 2019 10:12:26 GMT por David Miguel Trujillo
Great Josef it works!
Thanks a lot for your help, it's very well explained,
Best regards, David.
