Publicado Mon, 17 Mar 2025 18:35:39 GMT por Waylon Courvell Initium Softworks LLC Technical Support Engineer
I want to utilize the workflow activity title for adding descriptions. For example, I have an assign data activity, the name of the activity is "assign data #1". If I modify the name, will this disrupt any logic, anywhere? Web services, database, etc.
Publicado Tue, 18 Mar 2025 10:39:40 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Waylon Courvell,
changing the names of workflow activities *should* not disrupt any logic.
I can only think of one case, where this could become a problem:
If you have an external, self-coded application, which connects to the DocuWare REST API and either completes Workflow Tasks on a user's behalf or collects data about specific workflow tasks.
If this is not the case for you ( like 99.9% of the customers), then it should be fine.
I have never had any problems changing names of workflow activities in the past 8 years.
Publicado Tue, 18 Mar 2025 13:15:36 GMT por Waylon Courvell Initium Softworks LLC Technical Support Engineer
Thanks!
