Publicado Tue, 02 Apr 2019 09:01:19 GMT por Kjetil Kulterud Service Owner
How can I set up so the RO website in DW can have another URL than "http://somethingsomething/DocuWare/Platformro/WebClient/"
The customer want an easier URL. Like http://docuware.read/docuware or something.
Publicado Tue, 02 Apr 2019 09:57:51 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Keeping in mind that the first part of the URL is either the machine name, a qualified internet address, or an IP address you cannot use "docuware.read" unless you install platform Read only on a machine called "docuware.read". This is because both the full licensed version and the read only version reside on the same machine.
Better would be to use some form of IIS redirection. So the user will enter http://machine name/DWRead or something like that, and IIS can then redirect to the correct read only URL.
https://docs.microsoft.com/en-us/iis/configuration/system.webserver/httpredirect/
Using redirect you do not interfere with DocuWare's internal structures.
