Publicado Thu, 12 Jan 2023 08:14:03 GMT por Renoux Marais Post Sales Solutions Consultant
Hi guys.
I have an issue where if I want to copy data filled in over the workflow to my document (Before Flattening) I cannot use the copy on the system. I have to either go into index entries or enter the data manually. If I do copy it, it just shows blocks as per attached.
I used to be able to do this. Why has this changed?
Publicado Fri, 20 Jan 2023 00:00:18 GMT por Matthias Wieland Senior Director Support EMEA
Dear Renoux Marais! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-194641-D8K3Z for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Publicado Fri, 20 Jan 2023 09:45:00 GMT por René Koop Specialist Software Support
Dear Mr. Marais,
We have identified and implemented a fix to improve the workflow issue. This is currently undergoing further testing to ensure that it does not cause unwanted behavior.
We apologize for any inconvenience this may have caused and thank you for bringing this to our attention. It is planned to release this as soon as possible.
