Publié Mon, 28 Jan 2019 15:25:59 GMT par John DeLaat
I have a workflow configuration that I would like to use in another file cabinet, when I copy the configuration it greys out the file cabinet, is there a way to copy a cofiguration and use in a different file cabinet than the one is was created in?
Publié Mon, 28 Jan 2019 15:30:00 GMT par Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Edit.
Assuming you are referring to Workflow Manager, the answer is no. There is no way to import or export a workflow design at this time.
This includes the ability to copy a workflow and change the file cabinet.
Publié Mon, 28 Jan 2019 15:38:30 GMT par John DeLaat
Yes, I am referring to workflow manager.  Thanks for the response.
Publié Thu, 03 Dec 2020 19:31:39 GMT par Brett Bonde Ricoh Canada Inc. Solutions Integrator
I see that this response is 2 years old.  Has anything new happened that would enable me to export a Workflow from my on-prem system to a Customer's DWCloud system?
Publié Wed, 30 Jun 2021 22:10:19 GMT par Marcin Kratiuk
Did Workflow Export from DocuWare 7.4 satisfy your requirements ?
