Publicado Mon, 28 Jan 2019 15:25:59 GMT por John DeLaat
I have a workflow configuration that I would like to use in another file cabinet, when I copy the configuration it greys out the file cabinet, is there a way to copy a cofiguration and use in a different file cabinet than the one is was created in?
Publicado Mon, 28 Jan 2019 15:30:00 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Edit.
Assuming you are referring to Workflow Manager, the answer is no. There is no way to import or export a workflow design at this time.
This includes the ability to copy a workflow and change the file cabinet.
Publicado Mon, 28 Jan 2019 15:38:30 GMT por John DeLaat
Yes, I am referring to workflow manager.  Thanks for the response.
Publicado Thu, 03 Dec 2020 19:31:39 GMT por Brett Bonde Ricoh Canada Inc. Solutions Integrator
I see that this response is 2 years old.  Has anything new happened that would enable me to export a Workflow from my on-prem system to a Customer's DWCloud system?
Publicado Wed, 30 Jun 2021 22:10:19 GMT por Marcin Kratiuk
Did Workflow Export from DocuWare 7.4 satisfy your requirements ?
