Registrato Fri, 17 Mar 2023 09:38:56 GMT di Ameen Nihad Business Manager
I have one workflow created as a test by one user, that user has been deleted from the system, how can I delete that workflow.<br> I'm the organization admin, but I don't have the right to do anything with that specific workflow from Workflow Designer.<br> <br> Please see attached screenshot
Registrato Sat, 25 Mar 2023 00:00:51 GMT di Matthias Wieland Senior Director Support EMEA
Dear Ameen Nihad! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-199234-V4N2Y for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Registrato Thu, 30 Mar 2023 06:00:24 GMT di Ute Degen Sr. Specialist Software Support Team GREEN EMEA
In this case, it is not possible to access/delete the workflow anymore. Doing this via the database can be tricky because of dependencies so instead it is good practice to add another user as designer, this user can then delete the workflow in the Workflow Designer as usual.<br> <br> Best regards,<br> Ute Degen<br> Technician Software Support Team Green EMEA<br> <br> &#160;
