Some users are dragging multiple files to a Document Tray and occasionally getting a message that implies (total) file size is too big. Would this be related to maxStringContentLength in the Desktop config?
Hello Jon,
i think that documents are bigger than 20 MB and DocuWare Platform by default cannot handle uploading files larger than that. Hot to increase this is described here:
https://www.docuware.com/support_faq/index.php?solution_id=4120
Mathias Schroll
Sr. Software Support Specialist Team BLUE EMEA
Dear supportteam,
i have the same problem. I can not open the linked document. The url ist not valid. Can you post the right link again.
Thanks.
Ottieni aiuto
