Registrato Wed, 17 Oct 2018 10:19:04 GMT di Casey Miller Director of Technical Services
I want to move documents from one cabinet to another.  I don't want to copy. Do I use the migration workflow? I tried the export but it just copies the documents over and the option to delete source document is greyed out. Docuware 6.10
Registrato Wed, 17 Oct 2018 10:28:50 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Migration is for migrating documents from one logical disk to another withing a file cabinet.
To move documents between cabinets you will use Export (up to 6.12) or Transfer (7 onward). The option in both modules "Delete source document" should be used to effect a move rather than a copy. Note that the source documents are only deleted after successfully storing them in the target.
Registrato Wed, 17 Oct 2018 10:56:38 GMT di Casey Miller Director of Technical Services
Phil, but I can't select delete source documents... its greyed out. See attachment.
https://www.docuware.com/sites/default/files/forums-images/Screenshot%20at%20Oct%2017%2007-55-53.png
Registrato Wed, 17 Oct 2018 11:01:27 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
That's interesting. What version? I'll need to look at that. I am not sure why it is greyed out.
Registrato Wed, 17 Oct 2018 11:20:05 GMT di Casey Miller Director of Technical Services
Registrato Wed, 17 Oct 2018 11:20:59 GMT di Casey Miller Director of Technical Services
6.10.0.637
Registrato Wed, 17 Oct 2018 11:24:12 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Casey,
My bet is that you have version control enabled on the source cabinet. In this case you cannot delete the source. You also cannot remove version control.
Registrato Wed, 17 Oct 2018 11:44:50 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Could it be as simple as not having deletion rights on the source file cabinet? Or do these workflows use an admin account that has all security rights?
Registrato Wed, 17 Oct 2018 11:55:30 GMT di Casey Miller Director of Technical Services
It is using Org Admin. Phil is correct, version control is enabled. Phil, after I export, can I just run a deletion workflow on same parameters and get the same results?
Registrato Wed, 17 Oct 2018 12:08:30 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Casey,
Yes and no. I would not trust that every document gets exported. Some may fail for one reason or another, and unless you keep careful track, you may delete documents that you shouldn't. So let's do this with a bit of panache.
1. In the source cabinet create a new numeric field and call it: ORIGDOCID.
2. In the source cabinet create a text field called OKTODELETE.
3. Run a SQL script on the source table to copy the DWDOCID to ORIGDOCID.
4. Create exactly the same field ORIGDOCID in the target cabinet.
5. Run the export workflow ensuring that you map ORIGDOCID to ORIGDOCID.
6. At the completion of the export you now have a reference from Target back to Source.
7. Create an Autoindex workflow, iterating the Target, and matching ORIGDOCID to DWDOCID in the Source.
8. Match first found document and update the OKTODELETE field in the source cabinet with "YES".
9. Create a deletion workflow that deletes document where OKTODELETE = "Yes".
Now you have control and won't lose any documents. You mave have to run the script in 3, for new documents periodically.
Phil
Registrato Wed, 17 Oct 2018 12:20:50 GMT di Casey Miller Director of Technical Services
Great Idea. I will do this. Thanks, Phil!
