Registrato Tue, 03 Dec 2019 21:53:14 GMT di Chris Tabar Systems Analyst
Greetings.
Is there a way to increase the length of time that the links sent out for password resets from within Docuware are good?  Our system currently seems to be set to 60, possibly even just 30, minutes, which is far too short.
This is for Docuware 7.1.
Thank you,
Chris
Registrato Wed, 04 Dec 2019 12:33:34 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Chris,
for on-premise systems, you can change this timeout, yes. The maximum is 24 hours.
However, I do not remember where to change this - it was in some configuration file on your frontend server, I recommend asking DW Support about this.
(And kindly update this thread if you found the location)
