Toggle navigation
Forum
Knowledge Base
Stato
Download
Richieste di supporto
Tutto
Tutto
Pagine Web
Forum
Articoli della Knowledge Base
Filtro di Ricerca
Tutto
Pagine Web
Forum
Trova risposte
Italiano
Deutsch
Español
Français
English
日本語
Italiano
Accedi
Home
Forum della comunità
Questions about usage and configuration
line break as a delimiter in export tool
Registrato
Mon, 04 Sep 2023 13:45:57 GMT
di
Thomas Guichard
In order to set up an accounting export I have to define a line break as a delimiter, but I have no idea how, is it possible? Thanks in advance
Registrato
Wed, 06 Sep 2023 09:59:20 GMT
di
DocuWare GmbH
Hi Thomas Guichard,
Do you need a line break as field delimiter? Instead of e.g. a comma or a semi-colon?
Maybe you could share a sample file to understand the needed structure.
DocuWare GmbH
Registrato
Thu, 07 Sep 2023 14:26:48 GMT
di
Thomas Guichard
Hi Tobias Getz,
Thanks for your reply
The export file is very specific and there is no comma or semi-colon, each information is in a new line as you can see in this file provided by the customer
Thomas Guichard
DSC
Rex-Rotary
ACHATS - Copie.txt (28,5 KB)
Registrato
Thu, 07 Sep 2023 14:42:20 GMT
di
DocuWare GmbH
Hi Thomas Guichard,
I assume this should work if you use the "Predefined Entry" with the value "New Line" in between your index entries.
DocuWare GmbH
Ottieni aiuto
Cerca nella Knowledge Base
Chiedi alla community
Nuova richiesta di assistenza
