Publicado Mon, 04 Sep 2023 13:45:57 GMT por Thomas Guichard
In order to set up an accounting export I have to define a line break as a delimiter, but I have no idea how, is it possible? Thanks in advance
Publicado Wed, 06 Sep 2023 09:59:20 GMT por Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Thomas Guichard,
Do you need a line break as field delimiter? Instead of e.g. a comma or a semi-colon?
Maybe you could share a sample file to understand the needed structure.
DocuWare GmbH
Publicado Thu, 07 Sep 2023 14:26:48 GMT por Thomas Guichard
Hi Tobias Getz,
Thanks for your reply
The export file is very specific and there is no comma or semi-colon, each information is in a new line as you can see in this file provided by the customer
Thomas Guichard
DSC
Rex-Rotary
Publicado Thu, 07 Sep 2023 14:42:20 GMT por Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Thomas Guichard,
I assume this should work if you use the "Predefined Entry" with the value "New Line" in between your index entries.
DocuWare GmbH
