投稿済み Wed, 20 Mar 2019 17:18:15 GMT 、投稿者 Casey Miller Director of Technical Services
I have a workflow setup that when the application is approved it autofills an Approved Date field with current date. is there a way in the workflow manager that we can also fill in the Expiration Date? I can't figure out how to calculate this? It is 3 years after approval date.
投稿済み Wed, 20 Mar 2019 17:23:46 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Casey,
2 Date variables required - GV_APPRO_DATE and GV_EXP_DATE.
GV_APPRO_DATE = CURRENTDATE
Assign this in a a data assignment step.
Create a new data assignment step (don't try to do these in one step).
GV_EXP_DATE = DATEADD("yyyy",GV_APPRO_DATE,3)
This will add 3 years to the approval date.
投稿済み Wed, 20 Mar 2019 17:25:53 GMT 、投稿者 Casey Miller Director of Technical Services
Great information. Thanks, Phil!
投稿済み Fri, 22 Mar 2019 15:16:25 GMT 、投稿者 Casey Miller Director of Technical Services
Phil, i have tried this but it isn't validating. This is the error it is giving me. See attached.
投稿済み Fri, 22 Mar 2019 15:29:06 GMT 、投稿者 Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Well that's plain unfair, because I reversed the criteria. Oops.
Try this:  DATEADD("yyyy",3,GV_APPRO_DATE)
投稿済み Mon, 30 Mar 2020 12:44:57 GMT 、投稿者 Koen Logghe Toshiba Tec Netherlands Technical Support Specialist Software
Dear Phil,
Thanks for this explaination, I would like to add some days, e.g. 5 to my date.
I should expect below command is for that:
DATEADD("dd",5,GV_ApproveDate)
But I receive below error:
 [2: ExpiredDate] Invalid Argument Value for argument Interval: [DD]
Can you please tell me where is the wrong ?
Best regards,
Koen Logghe
投稿済み Mon, 30 Mar 2020 13:34:11 GMT 、投稿者 Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Koen,
you are using the wrong syntax. Please refer to this page: DateAdd in VBA
Your command should be:
DateAdd("d",5,GV_ApproveDate)
投稿済み Mon, 30 Mar 2020 14:35:42 GMT 、投稿者 Koen Logghe Toshiba Tec Netherlands Technical Support Specialist Software
Hi Simon,
Thanks a lot, this helped me out !
Best regards,
Koen Logghe
