投稿済み Wed, 11 Mar 2020 14:35:59 GMT 、投稿者 Steve Shriver Application Specialist
We know that we can trigger an AutoIndex job by placing or changing a CSV or delimited text file in a Windows folder, if that text file is used as a data source in the AI job.
Would that same mechanism work for a database table if it was used as a data source in the job?
For example, the data source for an AI job is an MS-SQL view. New entries are made in the underlying table so that the view gets updated. Will that change trigger the AutoIndex job?
投稿済み Wed, 11 Mar 2020 14:36:59 GMT 、投稿者 Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Steve Shriver! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-122609-L1W6C for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
投稿済み Mon, 20 Apr 2020 22:51:09 GMT 、投稿者 Jon Weston File IT Solutions Sr Application Developer and RIM specialist
afaik it doesn't work that way but I'm curious to know what Support has to say - is there a workaround for this?
投稿済み Fri, 24 Apr 2020 14:59:48 GMT 、投稿者 Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Jon,
I am not answering for support, but actually you are correct, there is no way to trigger a database event.
Director Product
