Veröffentlicht Mon, 26 Nov 2018 08:15:17 GMT von Jochen Weissert
Dear Community,
I am not sure whether this is the right place to ask questions about storage robot.
From time to time the storage robot service crashes and it won't import any pdf files into DocuWare anymore. Only after restarting the storagerobot.exe manually the import configurations start working again. I checked the windows event log and I got the information that there is a problem with the module: C:\Windows\system32\MSVCR120_CLR0400.dll
Furthermore I get this Information from .NET Runtime
Application: StorageRobot.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
Do you have any idea what I can do to solve this problem?
Thank you in advance,
Jochen
Veröffentlicht Tue, 27 Nov 2018 06:27:56 GMT von Gilles Sauvagnat Altexence Président
Dear Jochen
As far as I know storagerobot is a third party application using DocuWare SDK
Have you made any kind of update (Windows, DocuWare). If yes you should ask the storagerobot vendor to check compatibility issues.
Gilles
Veröffentlicht Tue, 27 Nov 2018 08:02:02 GMT von
Hi Jochen,
update problem sounds possible.
Check your application pools in iis and the used .net version there.
maybe there was an update of .net, and now the version which is needed from storage robot is not longer in use?!
BG
Martin
