Veröffentlicht Thu, 07 Nov 2019 15:48:56 GMT von Brian Osborn Applications Systems Analyst
I am trying to add a carriage return line feed control CrLf within an arithmetic expression.  It validates the syntax, but the desired output is not happening.   Any pointers would be greatly appreciated.  The control characters are discussed on page 4 of the Workfow Expression Parser document.
Brian O
Veröffentlicht Thu, 07 Nov 2019 17:01:50 GMT von Tim Ohm
If that's just a straight VB statement....insert characters with ASCII codes - Chr(10) + Chr(13).  There is also a predefined vb variable - vbCrLf.  Not sure if DW will support either method.
Veröffentlicht Thu, 07 Nov 2019 17:38:59 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
That won't work. The Workflow Text field is a single line field. It does not accept multiple lines, therefore it will not recognize the code.
Veröffentlicht Thu, 07 Nov 2019 17:58:47 GMT von Brian Osborn Applications Systems Analyst
Hi Phil, I am actually using the 'Description' designation within the task which appears to have no trouble displaying wrapped lines of text.
Brian O
Veröffentlicht Thu, 07 Nov 2019 18:11:12 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Ok. Yes, the description is multi-line.
Try these things:
1. Remove the brackets from around CrLF.
2. Try the control chars Chr(10) + Chr(13) instead of the code. But! Be careful. In VB "+" signs mean to add not to concatenate. Now I think we use a mix of C and VB so the plus signs are probably ok, but in VB I use an ampersand & for concatenation.
3. Try  newLine rather than CrLF.
4. Finally just for fun  if all else fails try vbNewLine.
Other than that I am not sure and it would need to be tested further.
Veröffentlicht Thu, 07 Nov 2019 18:49:37 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
It does not work. I tried the code, the vb Constant and the ascii chars. Both directly in the text of the description and via a string variable.
