Veröffentlicht Tue, 11 Aug 2020 07:46:08 GMT von Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi all,
I implemented automatic stamping in a service.
In general, this is not a problem, just creating a DocumentAnnotationsPlacement object and Post to Annotations.
DocumentAnnotationsPlacement documentStampPlacement = new DocumentAnnotationsPlacement()
                    Annotations = new List<SectionAnnotationsPlacement>()
                        new SectionAnnotationsPlacement()
                            PageNumber = pageNumber,
                            SectionNumber = sectionNumber,
                            AnnotationsPlacement = new AnnotationsPlacement()
                                Items = new List<object>()
                                    new StampPlacement()
                                        StampId = stampId,
                                        Layer = layer,
                                        Field = new List<FormFieldValue>()
However, it always requires a Stamp ID. I can not figure out how to stamp with a stamp name instead of the GUID.
Using the GUID works just fine in on-premise systems, however I think you can not retrieve the GUID for stamps in Cloud systems, at least I do not know how to do that.
Can you help me figure out how to either find the GUID in a Cloud system or how to stamp without knowing the GUID?
Thanks and Greetings from Germany,
Veröffentlicht Tue, 11 Aug 2020 08:22:31 GMT von Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Simon,
stamping by name is not possible as the stamp name is not unique in a DocuWare organisation. It is possible to get the GUID of a stamp when using the development tools of a browser (search for "stamp" in "Network" after opening a document) or use this request which returns all stamps in JSON:
https://[name].docuware.cloud/DocuWare/Platform/WebClient/Viewer/Stamps?fileCabinetId=[FileCabinetGUID]&stampType=Text,Bitmap
DocuWare GmbH
Veröffentlicht Tue, 11 Aug 2020 08:29:02 GMT von Gilles Sauvagnat Altexence
Hi
Try
https://YOURORGANIZATION.docuware.cloud/DocuWare/Platform/Home/XSL
Then  List Organizations
Then
Then in the file cabinet you want
At that point you shoud get the stamp GUID you want
Hope it helps
Gilles
Veröffentlicht Tue, 11 Aug 2020 08:29:46 GMT von Gilles Sauvagnat Altexence
Oups 7 minutes too late :-)
Veröffentlicht Tue, 11 Aug 2020 08:54:38 GMT von Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi and thanks to both of you, that helps a lot.
