Veröffentlicht Thu, 02 Mar 2023 16:45:17 GMT von Jeff Slack ECM Specialist
I have a use case where a US company is scanning records from Mexico which uses the format DD/MM/YYYY, but also needs to store date fields in the MM/DD/YYYY format.
As I understand it, the date format is set by the language settings of the OS, but that limits me to either one date format or the other.
Does anyone know of a way to configure different date formats in a single store dialog to accommodate this?
Veröffentlicht Fri, 10 Mar 2023 00:00:20 GMT von Matthias Wieland Senior Director Support EMEA
Dear Jeff Slack! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-198122-L8X2B for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Veröffentlicht Tue, 21 Mar 2023 16:50:11 GMT von Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Jeff,
internally DocuWare always stores date in the same format, only the representation is defined on UI level. So every user can decide, in which format he/she wants to see the date. This setting is then also applied to stamps.
Additionally there is a default setting for the whole organization, this is e.g. used if an email is sent out which includes a date. I think in your case it would be beneficial to use a date format which is recognized in both countries (e.g. YYYY-MM-DD).
Depending on the type of documents there are also different options to recognize the date on the document.
