Veröffentlicht Fri, 25 Jan 2019 18:11:25 GMT von Nathan Werth
What are the current Java requirements for DW 6.12 and up?
I have been having a lot of Clients ask if both the JRE and Development packages are needed.  I know the JRE is needed for full text if being used and DW itself doens't require it.
Also, has there been any issues updating Java on DW server and it breaking full text?
Nathan
Veröffentlicht Fri, 25 Jan 2019 19:09:32 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Nathan,
6.12 requires JDK 8-131 and DocuWare 7 requires JDK 8-171.
With these releases it is usually ok to update the JRE. Sometimes this can cause problems if Tomcat is looking at the wrong path.
This FAQ article discusses how to correct that:
https://faq.docuware.com/en-us/knowledgebase/article/KBA-35542
The version of the JDK for any release can be found in the installation folder under javasdk.
Senior Director Support DocuWare.
Veröffentlicht Fri, 25 Jan 2019 21:04:16 GMT von Nathan Werth
Thanks the the information Phil!  I'll pass this along.
