Veröffentlicht Mon, 17 Sep 2018 11:18:39 GMT von Larry Stover President
After changing user password due to a prompt in DW7 the services start, but I get a http 503 error when loading the webclient.  What else needs to be changed to fix the 503 error?
Thank you,
Larry Stover
Veröffentlicht Mon, 17 Sep 2018 11:36:01 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Larry,
What passwords did you change?
Veröffentlicht Mon, 17 Sep 2018 11:54:13 GMT von Larry Stover President
Phil,
I changed the services that ran on my dwservices user - Authentication, Workflow, Background processes & Full text.  These had a log on error after the password was changed.  Changing these let the services start again.
Larry
Veröffentlicht Mon, 17 Sep 2018 11:57:00 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Larry,
You should avoid having to change these service user passwords by making them strong passwords and setting them to never expire. Otherwise you have a maintenance chore every 90 days that you must be on top of. Please also reset the passwords of the DocuWare App Pools. They use the same service user defined during installation.
Veröffentlicht Mon, 17 Sep 2018 12:14:42 GMT von Larry Stover President
Phil,
I found the app pool, but don't see how to change the paswords.  Also how do you make the password non expiring?
Thank you,
Larry
Veröffentlicht Mon, 17 Sep 2018 13:49:45 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Select the App Pool in IIS manger, Select Advcanced settings > Select the ellipses on the right side of the App Pool user, Enter the user name exactly as it currently appears and enter the password twice and select Ok.
Do this for all DocuWare App pools and do an IISRESET.
The password expiry is set either in Active Directory (domain user) or in the Users properties on a local machine.
Veröffentlicht Mon, 17 Sep 2018 14:06:08 GMT von Larry Stover President
Thank you Phil.  It worked.
