Posted Mon, 12 Feb 2018 19:40:23 GMT by Ron VandenLangenBerg Applications Developer
One of my users was in a multiple cabinet search and called because she was getting a "Dialog with id i_*long number* is not available for user *username*.  Moving it over and opening the same record in the correct file cabinet allowed the change.
The "change index" is not in the right click dropdown list.  The viewer does not show the indexes  But the index is available under tools with the Show Index Entries Tool (see red circl in picture).  Using this we can see the system data for the record.
So why can't a user edit an index on a multiple file cabinet search?
Thanks.
https://www.docuware.com/sites/default/files/forums-images/Docuware_ScreenShot.png
Posted Mon, 12 Feb 2018 19:48:00 GMT by Phil Robson DocuWare Corporation Senior Director Client Services, Americas
Ron,
Before we can respond I need to know what version of DocuWare?
While the multi-cabinet search knows which cabinet the document is from, the Index entry dialog for the applicable cabinet is not available (hence the error). But I will confirm that when I know the version.
Posted Mon, 12 Feb 2018 19:54:53 GMT by Ron VandenLangenBerg Applications Developer
Version 6.11 might have been sufficient, but giving you the build leaves you with no doubts.
Posted Mon, 12 Feb 2018 19:58:37 GMT by Phil Robson DocuWare Corporation Senior Director Client Services, Americas
6.11 was fine. The build number is just the production build. Hot Fixes don't change that number.
Posted Mon, 12 Feb 2018 20:17:25 GMT by Phil Robson DocuWare Corporation Senior Director Client Services, Americas
When you create a multi-cabinet search the first cabinet is the primary and it is this cabinet's dialogs that are used. Therefore, if you open the index entries from the viewer option and the document belongs to the primary cabinet then you can edit and save without error. However, if you open a document from the secondary cabinet, and try to edit it you will get an error because the dialog for that cabinet is not attached to the result list.
The error may differ depending on circumstances. For example, my error was that a specific field did not exist in the other cabinet.
My opinion is that the behavior is by design.
Posted Mon, 12 Feb 2018 20:23:30 GMT by Ron VandenLangenBerg Applications Developer
Is it an oversight that the "Show Index Icon" in the tools section is still enabled since the other two index access points are disabled?
The index is the same for all three of the file cabinets we have joined together otherwise it might have been more apparent which index we were seeing.  Thanks for the information.
Posted Mon, 12 Feb 2018 20:58:24 GMT by Phil Robson DocuWare Corporation Senior Director Client Services, Americas
Ron,
You make a good point. I will look at version 6.12, and the upcoming 7.0 to see if the behavior has changed at all.
Posted Tue, 13 Feb 2018 17:10:06 GMT by Joe Kaufman Bell Laboratories Inc Application Development Manager
Phil,
It would definitely be nice to know the outcome of this. In my opinion, if two out of three indexing spots hide the functionality on multi-cabinet results (even if the selected document is from the "primary" search dialog), then it should be hidden everywhere. The fact that it works for the primary but not for the others makes it all the more confusing, and just shouldn't be allowed now that we understand how a multi-cabinet result list is really sort of a nebulous. user-driven concept. To keep security intact and prevent confusion, it would be better if changing such indexes was not allowed across the board.
Alternately, if multi-cabinet searches could be created at the configuration level (not user by user), then dialogs could be created and assigned privileges and everything would work as it should. However, it appears to be pretty ingrained (especially with regard to Platform SDK resource entry points) that dialogs are under a single file cabinet. My guess is that configuring multi-cabinet searches as persistent dialogs is not in the cards for a loooong time.
Posted Thu, 15 Feb 2018 12:50:00 GMT by Joe Kaufman Bell Laboratories Inc Application Development Manager
Phil,
Were you able to find anything out on this matter, including if something will change in a future version (if it hasn't already)?
Posted Thu, 15 Feb 2018 13:23:43 GMT by Phil Robson DocuWare Corporation Senior Director Client Services, Americas
We just completed the investigation and the behavior is the same in both releases. You can edit Index entries if you are editting a document from the File cabinet that serves the Dialogs (normally the first one selected). If you try to edit a document from the second cabinet you get an error.
I have not investigated yet if there are any plans to change this behavior.
