Posted Wed, 03 Apr 2019 17:24:24 GMT by Julio Velasquez No longer there
I have a web form where I will like to auto-populate the city field based on zip code.. has anyone done this?
Posted Thu, 04 Apr 2019 12:55:16 GMT by Casey Miller Director of Technical Services
DocuWare Forms doesn't have an option for database links or for autofill. This would be a good idea to share and get votes to be added. I would like to see it in the web client as well.
Posted Sun, 05 Feb 2023 08:44:13 GMT by Jamshad Mohamed Biyyathil Project In-Charge
I too have the same query.
On FORMS the index filed needs to be populated from DB on entering the Employee or Student ID.
This will reduce the time for user filling all the fields again & again.
Posted Mon, 06 Feb 2023 14:44:01 GMT by Connie McMahan Software & Database Manager
You can do this now on newer versions of DocuWare using a multi-column select list.  You would need to create a multi column select list that has all of the zip codes and city names.  Then point the Form to this, select the correct column, then check the box to autofill if only one entry.
